Old 03-27-2023, 07:22 PM   #127
eldersCAMARO
CamaroLove
Drives: 2023 ZL1 Shark Skin
Originally Posted by FollowMyLine View Post
Yes, it sure is!
Thanks! for personal future reference, where can I find out exactly what to use if its. not in the manual? ect...contact your dealer and in my experince most dealers are clueless
eldersCAMARO is offline   Reply With Quote
Old 03-27-2023, 07:28 PM   #128
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Your best bet is honestly to come here. Lots of us have access to service manuals, and have affiliations with GM, or know specific people who developed and worked on the 6th Gen. Platform.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 04-06-2023, 11:09 AM   #129
FollowMyLine
Driver for Hire
Looks like the diff fluid is on sale at Amazon for $16.34 a quart!
ACDelco GM Original Equipment 10-4034 Dexron LS 75W-90 Gear Oil - 32 oz
The bottle design has changed though, and it uses a wide mouth opening now. You can use this pump now if you don't already have one:
Slippery Pete Fluid Pump for Gallon Bottles and Wide Mouth Quart Bottles
Luan Zeqollari
YouTube Channel
Old 04-06-2023, 01:50 PM   #130
Camaro Fanatic
Drives: '23 1SS 1LE
Great find, appreciate you sharing with us! Also love your videos, kept me sane while I waited to take delivery.
Camaro Fanatic is offline   Reply With Quote
Old 04-06-2023, 02:10 PM   #131
FollowMyLine
Driver for Hire
Awesome to hear! I’ll have another one soon on getting a factory ZL1 “track ready.”
Luan Zeqollari
YouTube Channel
Old 04-12-2023, 08:40 PM   #132
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I like this over a pump.
Got mine at WM though
https://www.amazon.com/Hopkins-10106.../dp/B000EH4UXM
Old 04-13-2023, 09:16 AM   #133
FollowMyLine
Driver for Hire
I have since switched to a transfer pump
Steel Tube Fluid Transfer Pump
Luan Zeqollari
YouTube Channel
Old 01-07-2024, 02:09 PM   #134
WishfulSS
Drives: 17 Volt, 20 Mustang, 2015 Boxster S
Originally Posted by Jastone View Post
That is the correct gear fluid. Look in the performance supplement and you'll see that the fluid specs in there are for ZL1 models only. It states refer to the owner's manual for 1le equipped vehicles.
Cross reference owners manual part number Dexron LS gear oil GM part number 88862624.
Are you getting confused about the eLSD clutch fluid? That fluid is NOT what needs to be changed after 1500 miles and before the first track day.
As mjk said, it's very easy and intuitive to changes rear gear oil.
Raise vehicle,
Remove fill plug,
Remove drain plug,
Drain oil,
Replace drain plug,
Fill rear end with fluid (1.2qt)
Replace fill plug,
Lower vehicle,
Drive vehicle for a few circles (left and right),
Raise vehicle,
Remove fill,
Check level (fill as needed),
Reinstall fill,
Lower vehicle,
Done
I think the confusion is believing the eLSD constitutes the need for different "gear oil", that's false. The eLSD needs a separate change (when needed, not after 1500 miles) of clutch fluid 5.4oz.
For a simple gear oil change, nothing is special or different for 1le equipped vehicles
If we use a different gear oil, say Redline 75W-90 does the diff need the friction additive? Redline says it meets the GM spec for "Dexron®L.S. Gear Oil 88862624". Does GM sell it separately? Do we have a part number?
WishfulSS is offline   Reply With Quote
Old 01-07-2024, 02:28 PM   #135
FollowMyLine
Driver for Hire
That is the part number that includes the friction modifier. If the Redline bottle says it meets the requirements, then it should not need any additional friction modifiers.
Luan Zeqollari
YouTube Channel
Old 02-09-2024, 12:35 PM   #136
mdhunter03
Drives: Chevrrolet Camaro 2ss 1LE
Hi, Im new to the forum. I was wondering how often you change your rear diff after the initial first change.
Thanks
mdhunter03 is offline   Reply With Quote
Old 02-09-2024, 03:02 PM   #137
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
My Owner's manual says every 45k for the LSD.
