#127 | |
![]() ![]() ![]() ![]() Drives: police interceptor Join Date: Nov 2008
Edit: Also the Camaro is already more ridged than the Mustang. |
#128 | |
#129 |
Well... I'm speaking in General, Not every single case. GM don't have a Boss Competitor... I want a Z28!!! lol
#130 | |
Anywho Back on topic. |
#131 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
??? I thought the Gen V were supposed to be DOHC per the UAW/GM documents a few years ago. As for DOHC being obsolete, no chance. Too many advantages in every configuration, especially smaller, lower displacement engines.
#132 |
Drives: 4 Wheels, Gasoline Engine Join Date: Jul 2010
It doesn't matter how many times various people in the industry, including Fbodfather, state that large displacement, ohv v8 engines will go the way of the do-do due to cafe requirements, they continue to think it will be business as usual in the performance arena. Not the case.
#133 |
![]() ![]() ![]() Drives: 2010 AQUA BLUE CAMARO RS Join Date: Mar 2009
Yeah the Mustangs solid rear axle has really surprised me with how good it has been and what Ford has been able to do with it. It will be interesting to see what they do when they change over to idependent rear suspension for the 6th Gen Mustang in 2014.
#134 |
Yeah me too I would LOVE to see a new Z28 Camaro! I would hope that its not totally out of the price range for most people like the ZL1 is. Should be somewhere in between the SS and ZL1. It seems like the new 6th Gen Mustang is going to come out the end of 2013 as a 2014 from what I am reading and I have seen that the new 6th Gen Camaro is going to come out the following year at the end of 2014 as a 2015 model. I think that Chevrolet should bring the Z28 back as a new Camaro on the lighter 6th gen chassis. I'm sure the 6th Gen will already look great anyway and will sell on looks and performance alone but think about what a new Z28 being added would do at the launch of the 6th Gen Camaro that would be a BIG blow to the 6th Gen Mustang after only being out on the market for a year and would bring even more sales for the new Camaro.
#135 | |
![]() Drives: 2005 Magnum R/T Join Date: Mar 2010
Bored out 5.4?
If that's what the 5.8L is based on, it's a pretty compromised design. Maybe the 5.8 is based on the 6.2L? I had thought that engine was too tight a fit in the Mustang. Last edited by klapper; 10-08-2011 at 10:35 PM. Reason: clarity |
#136 | |
Drives: '11 Mustang GT Premium Join Date: Oct 2010
Although, both the GT500 and the ZL1 will probably fall flat on their faces on lap two... |
#137 | |
#138 | |
#139 |
Ahhh remember I said DOHC V8s not 4s or 6s. If the Gen V V8s gets concentric cam tech (as expected) and thus true VVT, D.I. , camshaft higher in the block (thus less valve train weight, as expected). Combined with the advantages inherent with OHV V8s, it could possibly be the best N.A. V8 made for per cost and packaging. In the future we already know GM is working on H.C.C.I. , and I was told that the Gen V new block makes it easier/cheaper for GM to use the designed yet not implemented 3 valve cyclender heads in the future SBC. If over the next 10 years all that tech is incorporated in the SBC, what suppose advantage would a N.A. DOHC V8 have over the OHV? None, infact DOHC would be almost inferior in everyway that matters in the real world.
#140 | |
Another big issue with a 2 valve, and in most cases all valve configurations (but more so in a small head OHV) is valve shrouding. This is when your only intake/exhaust valve is in close proximity to the chamber wall. This restricts airflow from sometimes 50% of the valve opening, on an OHC engine, heads are naturally larger so chambers can be designed around this problem and... there are additional valves to aid airflow. DOHC cams are hollow and easy to swap out compared to the old cam in block design. With a timing suppression tool, you can literally change 4 cams in a 1/4 of the time it takes to swap out a OHV cam. There are a lot of additional measures you have to take to get a cam out of the block.... If GM would have stuck with the Northstar, it would have been a fantastic engine and for some reason, Team Corvette took offense to the LT5 since it was built overseas. Besides, if OHVs were really that good, they would have stuck with them across the board... |
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ | AutoAgenda | V8 Bolt-Ons & Tunes | 7 | 07-11-2011 06:50 PM |
Engine Cleaning With Pictures | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 4 | 05-01-2010 11:00 PM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
