01-26-2020, 09:27 AM | #1 |
Drives: 2012 Camaro LS3 2SS Join Date: Oct 2018
LS3 RWHP Dyno Question
Hey guys, a couple of questions regarding LS3 RWHP Dyno numbers.
What would RWHP typically be for an SS LS3 Stock? Seems like I have seen 373-383 RWHP. Also, what would RWHP typically be for the same SS LS3 with long tube headers, HF cats, X-pipe, cold air intake, and tune? This is where I have seen a lot of variation regarding numbers. With this setup (see mods below), the dyno report from my tuner showed max Torque 439, and Max HP 438. Does that seem accurate? I realize different dyno's and temp makes a difference, thanks for the input.
Z/28 Cold Air Intake; ARH 1 7/8 Long Tube Headers, High-flow Cats, X-Pipe; Borla ATAK; 160 Deg. Thermostat; Craven Tune
01-26-2020, 09:58 AM | #2 |
Mine had weird numbers on a dynapack. 383 / 385 (give or take a couple) with CAI, 417/418 after LTH and tune.
Numbers aren't 100% accurate but pretty close. Can't find the darn print out anywhere... I did ask for a tune for the track, with more average power than peak in mind, but that doesn't really explain the baseline run which was CAI + a remote tune, the follow up LTH was tuned on the road and dynapack by Aikman.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
01-26-2020, 10:39 AM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Mustang dynos read less than Dynojet. Bone stock on a Dynojet in the dead of winter, my LS3 was 355 hp. As the 2013 was the first year with electric power steering assist, I would imagine 2013 hp would be slightly higher than 2012 with a power steering pump.
01-26-2020, 11:19 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
To see a true gain you would have to run a baseline, then mod and run it again on the same exact dyno. Take the numbers with a grain of salt, they are a tool to measure gains. The number can't fluctuate a LOT between dynos. Mine ran 575 at jannetty, then a few months later i did a dyno day more to hang out with ppl at slowhawk, his mustang dyno showed 595hp and 5 less torque and everyone says mustang dynos read lower. Grain of salt.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
01-26-2020, 02:56 PM | #5 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Figures seem reasonable; I'd say that's about right.
01-26-2020, 08:40 PM | #6 |
Stigs Bahraini Cousin
I made 410 whp with drop in air filter and cat delete.
My friend made 410 whp with airaid cai, pacesetter 1 3/4 LT headers and x pipe Mine is 1LE his is not and he put 2 cars lengths on me. Both same tuner same dyno and he tuned in a better weather condition.
2015 CAMARO 1LE
02-13-2020, 10:09 PM | #7 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i'm going to point at the elephant in the room,mustang is just a bad choice of a name for something used to measure power..
02-14-2020, 11:14 AM | #8 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
In September of 2009 after Kooks LT headers, hi flow cats, ported intake, Rotofab CI and dyno tune on a DynoJet, RW/HP was 414 and RW/TQ was 406. In 2010 after S/C on same dyno readings were RW/HP 546 and RW/TQ 521 with 11# boost.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
02-14-2020, 12:54 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Every vehicle will respond differently to a tune. Numbers will be what they will. Whats more important is that a competent tuner gets the most out of your tune.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
Thread Tools | |
