12-24-2019, 06:00 PM | #1 |
Weight reduction
What are the guys who done the extreme to shave weight, do for the doors and door glass?
Current curb weight on mine is 3640 with an iron block and twins.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
12-24-2019, 06:53 PM | #2 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Have a look here: https://www.camaro5.com/forums/showthread.php?t=170965
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
12-24-2019, 09:13 PM | #3 |
Drives: 5th Gen L99 Join Date: Nov 2017
3640 on an iron block and twins is a pretty good job so far.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
12-25-2019, 10:05 AM | #4 |
Drives: cheby Camaro Join Date: Aug 2019
I'm kind of surprised these cars have steel stamped lower control arms. I see all the Buick's come with aluminum suspension pieces. Has to save a bunch of weight.
12-25-2019, 02:50 PM | #5 |
Drives: 2015 Camaro Join Date: Aug 2018
12-25-2019, 04:38 PM | #6 |
Well I guess we got ripped!
Thread Tools | |
