Vararam
Old 07-21-2008, 02:00 PM   #1
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
Camaro LS / LT / RS / SS specs and options!
Here is some info for to those who inquired about car specifics. Subject to change, of course.
LS – 300-horsepower 3.6L
V6 DI engine, 18-inch Heritage
steel wheels, StabiliTrak®
Stability Control System with
Traction Control, ABS, six
air bags, OnStar® and XM®
Satellite Radio, all standard
LT – adds 18- or 19-inch
aluminum wheels, fog lamps,
6-way power driver’s seat,
interior ambient lighting
and more
SS – 400- or 422-horsepower
6.2L V8, 20-inch aluminum
wheels, SS-unique front fascia,
SS spoiler, exterior and interior
SS badging, 4-piston Brembo
brakes, leather-wrapped
steering wheel and shift knob,
6-way power seat, limited-slip
differential and more
RS Appearance Package
(available with LT and SS) –
HID headlamps, spoiler on LT
model, 20-inch 5-spoke wheel
with Midnight Silver paint
finish, RS unique taillamp,
body-color roof ditch molding
and RS badging (front and rear)
Front
* Wide, powerful stance that
signifies dominating sports
car road presence
– 75.9-inch overall
vehicle width
* Forward “face” that is
distinctly Camaro
– Front grille that
incorporates a
slight “V” shape
(First Generation
Camaro heritage)
and overall
aggressive look
– New Chevy bowtie
design that’s leaner,
more horizontal and
contemporary
– SS and RS
badging where
appropriate
* Aluminum hood with
“power bulge” contributes
to strong, powerful look
* Reverse Mohawk roof
that extends twin cockpit
theme inside
* Standard fog lamps
on LT and SS
* HID headlamps with
“halo ring” display
provide added visibility
(RS Package)
Exterior
Colors
Victory Red
Black
Rally Yellow
Silver Ice Metallic
Red Jewel Tintcoat
(additional charge)
Cyber Gray Metallic
Aqua Blue Metallic
Inferno Orange Metallic
Imperial Blue Metallic
White (July 2009)
Available Dual Stripe
Package (White and
Cyber Gray)
Interior Colors
Jet Black
Titanium Gray
Neutral
Inferno Orange
Interior Accent Package
3.6L DI VVT V6 ENGIN E
Standard engine on LS and
LT models
Projected 300 horsepower
and 273 lb.-ft. of torque
(automatic/manual transmission)
Direct Injection (DI) enables fuel
to be delivered directly to the
combustion chamber for a more
complete burn of the air/fuel
mixture – less fuel is required
One of the most fuel-efficient
offerings in GM’s high-feature
engine family, attaining an
estimated 26 mpg on the highway
Employs Variable Valve Timing
(VVT) to change the timing of valve
operation as conditions vary –
when combined with DI, it enables
unmatched power, efficiency and
low emissions
6.2L V8 ENGINE
Standard engine on SS models
Projected 400 horsepower and
395 lb.-ft. of torque (automatic
transmission) – L99 engine
Projected 422 horsepower and
408 lb.-ft. of torque (manual
transmission) – LS3 engine
L99 engine incorporates Active
Fuel Management (AFM) and
Variable Valve Timing (VVT)
for optimized valve timing and
improved fuel economy
SIX -SPEED MANUAL
AISIN TRANSMISSION
Standard with the 3.6L DI VVT
V6 engine
Lower shift efforts and shorter
shift throws
Closer ratios for more rewarding,
high-performance driving
Quieter operation
HYD RA-MATIC® SIX -SPEED
AUTOMATIC TRANSMISSION
Available with 3.6L DI VVT V6 and
6.2L V8 engine (L99)
One of the most technologically
advanced in the industry
Incorporates TAPshift® with
steering-wheel-mounted paddle
shifters for clutch-free six-speed
automatic transmission shifting
MORE HERE
Heritage Design
(First Generation Camaro)
■■ Instrument panel designed to appear
solid and refined
■■ Center console separated from
instrument panel for a much wider,
more spacious feel inside
■■ Available four-pack
gauges in the center
console (under the
radio) reminiscent
of the past
– Contemporary
graphics
– LED backlit
■■ “Deep dish” thick grip, three-spoke
steering wheel, leather-wrapped on
most models, is intuitive and iconic
– “Camaro” displayed in horn pad
– Thumbwheel controls right
where you need them (stereo
volume and cruise control)
Contemporary Execution
■■ Chrome and bright applications
throughout
– Steering wheel
– Horn pad
– Cluster
– Inside door handles
– HVAC outlets
■■ Special lighting around all gauges to
give a “floating” appearance
■■ Available ambient lighting runs across
the upper edge of the appliqué in the
instrument panel and doors using
LED lighting technology – provides a
subtle glow at nighttime
■■ Oversized knobs with chrome
detail and rubber grommets
that match Camaro’s bold,
simple character
■■ Contemporary, comfortable seating
with adjustable headrests
– Standard power recline driver and
front passenger seat
– Standard 4-way manual driver’s
seat and 2-way manual front
passenger
– Available 6-way power adjustable
driver’s seat
– Available leather-appointed, heated
front seating surfaces
Additional
Customer Delighters
■ Available express-open and venting
sunroof (first for Camaro)
■ Large glove box
■ Door map pockets
■ Two world-class cupholders
(fit numerous cup sizes)
■ Rear-seat
pass-through
■ Center console
bin storage with
auxiliary input jack
■■ Available Boston Acoustics Sound
Systems – the first application
in a GM vehicle
– 245-watt 9-speaker premium
Boston Acoustics Sound System
– 6.5-inch woofers in each door
– 1-inch tweeters in A-pillars
– 3.5-inch center channel speaker
in the upper Instrument Panel
– Seven-channel sub-woofer
on rear shelf
TREMEC® MANU AL
TRANSMISSION
■■ Standard with the
6.2L V8 engine (LS3)
■■ Shorter throws and
smoother gear synchronization
■■ Overall improved shift feel with
little or no vibration
■■ Wider gears for increased torque
and handling capability
RID E and HAND LIN G
■■ Near 50/50 weight distribution for
enhanced driving characteristics
■■ Twin ball joint strut front suspension
for precise handling
■■ Independent rear suspension for
increased refinement
– 4.5-link system with coil-over
shock absorbers and decoupled
stabilizer bar
– Designed to handle power of
the vehicle
– Better handling on rough surfaces
– A competitive advantage over
solid axle
■■ Variable rate rack-and-pinion
steering system for a sporty feel –
2.5 turns lock-to-lock
■■ Uplevel Brembo brakes with four
piston calipers (front and rear) with
racetrack stopping capability and
durability (standard on SS)
■■ Standard engine oil and transmission
oil coolers on SS
Sta ndar d Tire
Inflator Kit
■■ Convenient way to fix the majority
of potential tire problems
■■ Camaro is lighter in weight
with the Inflator Kit
■■ Available spare tire with LS and LT
models (not available with SS)
P E R F O R M A N C E
The
CamaroScotty is offline
Old 07-21-2008, 02:02 PM   #2
Hyperknight
Band.
Hyperknight's Avatar
Drives: 2016 2SS
You sir are the man. Stripe package!!
Hyperknight is offline
Old 07-21-2008, 02:03 PM   #3
Shadowsong
Drives: 2014 Mustang
I didn't see it anywhere, but does the LT/RS have a leather wrapped steering wheel?
Edit: And you can't get the stripes in black? :(
Shadowsong is offline
Old 07-21-2008, 02:04 PM   #4
pinkcamaro10
2G1FC1EV1A9110079
pinkcamaro10's Avatar
Drives: 2010 2LT/RS, 2013 2SS/RS 1LE
Send a message via MSN to pinkcamaro10
too much information at once, i want to cry and explode at the same time
anything about ambient colors????
pinkcamaro10 is offline
Old 07-21-2008, 02:05 PM   #5
swazworth
the nerd king
Drives: 2005 scion xb...
wow-> that is all i can say....... your the man
swazworth is offline
Old 07-21-2008, 02:06 PM   #6
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
darn skippy.
Originally Posted by fbodfather View Post
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline
Old 07-21-2008, 02:07 PM   #7
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline
Old 07-21-2008, 02:07 PM   #8
drivingincamaro
drivingincamaro's Avatar
Drives: 95 civic
do not worry they will have black stripes
drivingincamaro is offline
Old 07-21-2008, 02:09 PM   #9
CamaroScotty
WOW - I was watching a DEALER site....and I see the Chevy side popped up something as well.....
Cool though - SHARING THE LOVE!
Old 07-21-2008, 02:10 PM   #10
Shadowsong
Originally Posted by drivingincamaro View Post
do not worry they have black stripes
That's a relief
Old 07-21-2008, 02:11 PM   #11
jmliptak
Drives: D
You are the man, but we already knew that....Thanks!
jmliptak is offline
Old 07-21-2008, 02:13 PM   #12
Chogan2200
Chogan2200's Avatar
Drives: 96 Cavalier "Scarlet"
+ rep!!!
Chogan2200 is offline
Old 07-21-2008, 02:13 PM   #13
CamaroScotty
ADDED MORE DETAILS!
Old 07-21-2008, 02:14 PM   #14
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
That is awesome!
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline
OFFICIAL 2010 Camaro Specifications (full tech specs PDF inside) Tran Guides, Manuals, Bulletins, Documentation Archive 394 06-11-2010 06:16 PM
Camaro home page is up @chevy.com!!! Engine Specs and Official Colors! ChrisL 5th Gen Camaro SS LS LT General Discussions 66 07-22-2008 12:08 PM
10 coolest cars on film Camaro in top ten KILLER74Z28 Camaro Photos | Spyshots | Video | Media Gallery 26 05-15-2008 10:52 AM
