05-12-2016, 05:26 PM | #1 |
Drives: 2013 Camaro LS coupe Join Date: May 2016
Factory radio cuts off randomly
The factory radio in my 2013 LS with 75000 miles has started to cut off constantly by itself, just the standard radio without my link. It cuts itself off at random and sometimes when I hit the brakes or use a turn signal. My ac also quits blowing for a split second when it shuts off then comes back on. I have no problem with my headlights or power windows when it does this. I have only seen one thread about this exact problem but it was very old and no one commented on it. Does anyone know what my problem could be, maybe a faulty hvac controller ( the display and controls for the radio and the ac)?? thank you all for you time.
05-12-2016, 05:50 PM | #2 |
I had similar issue only once.. Nothing would work on the center control touch screen or control knobs and the AC was stuck blowing cold air on high speed and the entire system would not respond to any controls for 5 min. Then started working normal. Gotta be a short in these systems somewhere. Thank god it only did this once last year and been no issue since.
05-12-2016, 05:56 PM | #3 |
This is happening every time I drive the car now, cant listen to anything because it cuts off so much, very annoying. Gonna take it to a chevy dealer next week and hopefully my warranty will cover it.
05-14-2016, 09:55 AM | #4 |
Good luck . GM seems to not cover crap under warranty these days. They seem to find something to not cover the problems.
05-14-2016, 09:52 PM | #5 |
Happened to my Mylink I installed it eventually reset and it was fine...
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
08-22-2016, 09:37 PM | #6 |
Drives: 2013 LS Join Date: Aug 2016
Just out of warranty
My base level radio just began to suffer a similar fault (27,000 miles). As soon is the engine is started the all lights and screen on the radio/ac faceplate (controller) wig out along with the audio and the ac compressor cycles on and off with about the same freqency as everything else. The blower remains at about the same speed as it was previously set and can still be adjusted, no other apparent symptoms.
I tried a battery reset with no success. I heard that there is a update for a simlar fault but I think it is for only for the "my link" set up. I was not able to find a wiring diagram on the web either which was surprising considering it's for the radio. Annnnnnyway, I was thinking it had to do with what ever is supplying power to the faceplate either the bcm the radio unit or some power control module. I removed the faceplate and unpluged it with the radio and ac on with the engine running while trying to duplicate the fault. The whole time I was digging around (played with harness and connectors, mess with all fuses and relays, massaged the bcm, etc.) I was not able to duplicate the fault and it did not happen again unit I pluged the face plate back in. If you unplug the radio unit what a surprise, the radio turns off. It's worth mentioning I did not unplug anyother connector in fear of setting a fault and dropping a system into limp mode. Hmmmm this is not really the most technical way to diagnosis it but I'm looking that either there's a problem with comands (1s and 0s) stored in the faceplate's controller just from age which would mean there is an update ooooor the faceplate took a shit. I'll post what I find (I hope!) and if I get around to it I'll post the video of the fault via youtube. Peace |
08-23-2016, 12:49 PM | #7 | |
Drives: 2013 Camaro LS Join Date: Apr 2016
Let me know if you find a solution! Im going to check the fuse boxes when i get a chance. |
08-24-2016, 02:25 PM | #8 | |
Ive been driving with face plate unplugged and it seems to work fine lol. Im trying to find any TSBs for the base model radio. A new faceplate costs about 300 bucks, used for about 100. |
09-29-2016, 12:38 PM | #9 | |
Thanks! |
09-30-2016, 01:34 PM | #10 |
10-03-2016, 08:47 PM | #11 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Happened once on my 2015.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
10-06-2016, 09:02 AM | #12 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
My air controls stopped working and radio reboots. I pulled a fuse on the side of the dash drivers side, i think it said my link or radio and it cleared all the issues.
10-07-2016, 12:04 PM | #13 |
Drives: 2015 Camaro SS Black 6 speed Join Date: Sep 2016
So I just put 10k miles on my car about a week ago and this morning my touch screen display wasn't working. I can listen to music but after turning it off and back even restarting my car....nothing. I drive 45 minutes to work so there was enough time for it to kick back on. Guess I'm going to check the fuses when I get off work. If all else fails I'm pretty sure my warranty covers it, any other suggestions?
10-08-2016, 11:13 AM | #14 | |
Tags |
problem, radio |
Thread Tools | |
