04-06-2016, 09:45 AM | #1 |
RPI Designs 2016 Camaro SS Stainless Works Headers 2" Primaries Catted No Valves
2016 Camaro SS headers featuring port-matched flanges and 2" mandrel-bent primaries and 3" catted leads, x-pipe and tailpipes. Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers. Features: ‣ 3" diameter system ‣ 3" port-matched flanges ‣ Support For Dual-Mode Performance Upgrade Including Functioning Valve ‣ 304 stainless steel construction ‣ TIG welded for strength ‣ Mandrel bent (no buckling) for optimal flow ‣ Design and Made in Chagrin Falls, Ohio, USA Performance and Sound Proudly Made in the USA Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship. Make It Your Own With Custom Options Choose Your Connection: Stainless Works Camaro systems come in two configurations: Factory Connect and Performance Connect. Factory Connect allows our headers or exhaust to easily bolt to the factory exhaust or manifolds respectively. They connect at the factory location which is necked-down to accommodate fitment. Performance Connect is designed to take advantage of performance gains not possible with the standard factory connection point. Both SW headers and SW exhaust are used in this configuration. We've developed a system which maintains a full 3" diameter and X-pipe which creates the ultimate horsepower experience. Item # CA16HCAT Website Link: http://www.rpidesigns.com/shop/item....ted-no-valves/ |
06-12-2020, 07:12 AM | #2 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
2016-2018 Camaro SS Stainless Works Headers 2" Primaries Catted No Valves
01-06-2023, 11:11 PM | #3 |
Thank You for shopping at https://www.rpidesigns.com/shop/item...ted-no-valves/
03-29-2023, 01:30 AM | #4 |
Thread Tools | |
