09-10-2015, 08:29 AM | #1 |
Drives: 2011 2LT IBM / SIM stripe 6M Join Date: Apr 2010
Speaking of clutches
I have 2011 2LT with 60,000 miles. I've noticed the clutch pedal resistance getting weaker and weaker.
This morning my transmission would engage after only letting the clutch pedal up for about 1 inch of travel. I also notice that with the clutch pedal fully released it was only coming back towards me about half way. So later I took my hand and grabbed the clutch pedal and it freed to come back towards me the rest of the way. It then worked like normal so I dropped it off at the dealer this morning. Any speculation what it could be. I still have a couple months left on my powertrain warranty.
09-10-2015, 08:41 AM | #2 |
Drives: 14 1Le --14 chevy ss sedan 07shelby Join Date: Sep 2014
Weak pressure plate/ fingers - bad slave cyclinder or complete clutch assembly at 60k is very likely ..clutch is a wear item like brakes and not covered by warranty usually ..just my opinion as to what it could be .. Good luck let us know what they find
09-10-2015, 09:38 AM | #3 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
The cylinder/pump is substandard from the factory and will grind gears on most vehicles and produce pedal fade on some. While confirmed by three dealers in Houston, none of them will touch it as it is "factory spec".
This is well documented in the clutch sub forum with several after market successful DIY's. The first Clutch is covered 100% between 0 and 12,000 miles. If you pop a second clutch, the dealer has to prove 'abuse' to deny the replacement and most likely wont. They will not replace a third under warranty. |
09-15-2015, 07:47 AM | #4 |
The clutch didn't act up again. The dealer changed the fluid in the clutch cylinder, but said everything looked good !!
Thread Tools | |
