10-20-2014, 12:53 PM | #1 |
Drives: 2015 Black Z28 Join Date: Oct 2014
E85 Fuel
I'm wondering if the Z28 is designed to run on it, and if so does it increase the HP?
Thanks, |
10-20-2014, 04:37 PM | #2 |
Drives: chevy corvette Join Date: Apr 2014
If it could it would say so in the manual.
10-21-2014, 07:35 PM | #3 |
Drives: '15 z/28, '12 Boss 302, '13 427 con Join Date: Sep 2014
10-23-2014, 04:58 PM | #4 |
Fight Crime, Drive Armed
Drives: '14 2SS Yelo Maro, HD collection Join Date: Jun 2013
Alcohol requires MUCH more fuel to produce power. A buddy once ran a pure alky car on the street. He got about 3 miles per gallon...but it was a 13:1 compression 468 C.I. street monster .
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
10-23-2014, 05:42 PM | #5 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
+1000, E85 is a waste of food and you will get less MPG and most likely less HP! FYI, the higher the Octane the less alcohol that you have!
10-23-2014, 05:46 PM | #6 | |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
great post keep spreading false info on E85 Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
10-23-2014, 05:49 PM | #7 |
Go look at the 2014 silverado and the HP gains it has on E85 per GM. It adds an additional 20. Not saying this is typical for other vehicles just an example
Ryan
Ryan
10-23-2014, 05:55 PM | #8 |
Drives: 14 Z/28 0# Join Date: May 2013
On my 09 Suburban I tried E85 maybe 10 times and each time the fuel mileage was so far down it was never worth the cost savings.
"PTM11" Search & Destroy
10-23-2014, 05:57 PM | #9 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
10-23-2014, 05:59 PM | #10 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Alcohol produces less energy when it is burned so you have to burn more to get the same power as gasoline. Alcohol has a higher resistance to detonation so you can run higher compression and make more power.
10-23-2014, 06:15 PM | #11 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
just got a new work truck (2015 silverado HD with 6.0) and it says E85 on the gas cap.
filled up once with E85 and it got terrible MPG, have not put it in since
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
10-25-2014, 10:47 AM | #12 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
10-25-2014, 11:23 AM | #13 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
It has to get tuned for it, then yes the HP will increase.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
10-25-2014, 05:47 PM | #14 |
Moderator.ca
Its not just the tuning. Ethanol doesn't always play nicely with the rubbers & plastics found in most fuel systems. Tends to be corrosive. Cars that are E85 capable are built to accept ethanol in high concentrations. Most production cars are not, their limit tends to be about E20 or E25 before it starts to affect them.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
Thread Tools | |
