TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-24-2024, 04:00 PM   #15
Jtouch81
Drives: 2014 Camaro ZL-1
Never thought about using propane.. might be something to try. I haven’t had the lid off at all and haven’t had an issue as far as tuning it before installing the cam.
Not a bad idea on posting it to HP tuners forum
Jtouch81 is offline   Reply With Quote
Old 03-24-2024, 04:40 PM   #16
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Check the SC to valley cover hose
FasNuf is offline   Reply With Quote
Old 03-24-2024, 05:22 PM   #17
Jtouch81
I hate to sound dumb but which hose is that? Is it behind the supercharger?
Old 03-24-2024, 05:31 PM   #18
FasNuf
FasNuf's Avatar
No it's in the front. It looks like a 3/8 hose U shaped. You can see it under the black bypass dashpot looking thing.
Old 03-24-2024, 05:37 PM   #19
Jtouch81
checking now
Old 03-24-2024, 05:50 PM   #20
Jtouch81
Doesn't look to be leaking.. both ends are connected and locked. Started the car and sprayed some carb cleaner on the house and both connectors no change in idle.
Old 03-24-2024, 05:55 PM   #21
FasNuf
FasNuf's Avatar
Try the propane trick. Not all brake cleaner is flammable so it wouldnt change anything if sprayed on a leak. The hose if it uses an EFI connection could still be leaking at the oring inside the connector.
Anyway, try the propane sniff test everywhere and post your tune and log to the HPT forum.
Good luck
Old 03-24-2024, 05:58 PM   #22
FasNuf
FasNuf's Avatar
Worst case, if you cant find the suspected leak, the tuner can just correct the MAF for the leak.
Old 03-24-2024, 05:58 PM   #23
Jtouch81
Will do man thanks for your input I'll try to keep this updated on what I figure out.
Old 03-25-2024, 12:22 PM   #24
Jtouch81
Tuning issues
Okay got some replies back on HP forums.. was pretty much told that I need a new tuner and that this is something that’s all very basic stuff and an easy fix.. that’s disappointing to hear.
Glad it’s not something physically wrong… and I’ve been through the car with a fine tooth comb numerous times so I’m glad I’m not crazy but sucks that I’ve paid money to someone I trusted to tune it correctly
