02-11-2022, 05:28 PM | #15 | |
Hot Camaro
02-12-2022, 01:22 PM | #16 |
The camaro in my opinion has a pretty decent sounding horn unfortunately many drivers just ignore you and don't care just like many other vehicles out there seemingly don't have functioning turn signals.
08-30-2022, 09:35 AM | #17 |
Drives: Camaro gen 6 zl1 1le Join Date: Jun 2022
Hello Guys can anybody tell me who are the location from the horns ????
Or Pictures maybe I Hear just a click on the front of the car under the fusebox if I press it on the steering wheel. Fuse are OK must I remove remove the front bumper Thanks for your support guy's 🙏 |
08-30-2022, 10:28 AM | #18 |
Drives: Camaro SS 1LE Join Date: Aug 2018
08-30-2022, 11:25 AM | #19 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Get a horn out of a 5th generation Ram 1500, they are ubnoxiously loud
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
08-30-2022, 11:38 AM | #20 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Thread not resurrected by a spam bot but by an actual member in post 17 with a legit issue. While I don't have your answer, I do applaud you for using the search function first
08-30-2022, 11:49 AM | #21 | |
The location... well, to get to the horn (which is a dual horn) you need to remove the front bumper fascia, which sounds like a bit of work. The horns are located just in front of the hood latch mechanism and maybe about 6" down, where they are bolted to a cross member. EDIT: yep, it's a PCB relay: https://www.camaro6.com/forums/showp...3&postcount=16 Front fascia removal guide: https://www.camaro6.com/forums/showthread.php?t=443603 HORNS, AHOY! https://www.camaro6.com/forums/showp...1&postcount=14 Last edited by ctrlz; 08-30-2022 at 12:10 PM. |
08-30-2022, 12:12 PM | #22 |
Drives: Chevrolet Chevy Join Date: May 2022
I find my right foot is the best horn available. I think the terrible driver who illegally went straight into the freeway on ramp from an intersection that is only allowed to go left or right can attest to that.
08-30-2022, 01:08 PM | #23 | |
For the sake of measurement though, if you use the same device and same application, you would be able to measure the difference between a before and after.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
08-30-2022, 01:22 PM | #24 | |
Hot Camaro
As an aside, I've tried recording cold starts of my car using an iPhone, Google Pixel 6 Pro, GoPro Hero 8, and a Zoom H4 recorder. I've done this using very specific positions to set the devices, and the results in "how it sounds" across the different days I've done it changes pretty noticeably simply because of ambient noise differing. |
08-30-2022, 01:58 PM | #25 |
You could probably get pretty reproducible measurements in a garage. Unplug any fridge or freezer if needed. Distance and direction you hold the mic on a phone will also be factors. A lot of home theater receivers come with an omni for setting the speaker levels. Might be able to plug that into a laptop.
08-30-2022, 02:45 PM | #26 | |
Thanks man for your help also you mean if under the fusebox is clicking my kr3 relay are broken its right?? And this relay is integrated in to the fusebox is that right?? Also I need a new fusbox between this relay ?? Holy shit My horn was good before I remove the cable from battery bc the car was standing 2 months in the garage after this my horn doesn't working again I hope I can found the problem ... |
08-31-2022, 04:17 AM | #27 |
Hello Guys next day my horn works no issues anymore I don't touch anything I think my fusebox had issues I wanna changed that by a new one I think
Edit i hear the relay It's not more working again I order new fusebox we want see Last edited by Marozl1LE; 08-31-2022 at 07:35 AM. |
08-31-2022, 07:45 AM | #28 |
Drives: 2017 Camaro 2SS FIFTY convertible Join Date: Sep 2014
A few comments on this thread about NJ and NYC…
Some on here, might not know, but it’s a serious ticket if you are caught honking your horn in NYC…. It’s also likely, based on the fact that there are sometimes seem like four cops at every intersection….and violent crime is still rampant |
Tags |
horn |
Thread Tools | |
