Old 05-18-2016, 07:35 PM   #15
Soybeanrice
Soybeanrice's Avatar
Drives: 2014 2SS/RS
Did you have the 6 pistons on during LV?
Also, surely that cant be 18's with a 15.25 rotor right?
I saw the 6 pistons the z06 was running and its almost touching.. has to be less than 6 inches of room
Soybeanrice is offline   Reply With Quote
Old 06-06-2016, 04:36 PM   #16
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I did have this package on the car in Vegas. It works very well with a win in Speed Stop!
Kind regards,
Jordan Priestley
801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 06-08-2016, 11:26 AM   #17
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Originally Posted by OldJedi View Post
OK thanks Jordan. Is there anything to be gained with using Slotted/Grooved rotors over solid non grooved rotors?
Not Jordan, but I'll answer.
No. Slotted/grooved/drilled rotors offer no performance benefit at all. At least, not until you gut your interior, put in a cage, buy $10k shocks, put on race slicks, and hire a pro-driver.
http://www.stoptech.com/technical-su...rade-selection
DRILLED VS SLOTTED ROTORS
For many years most racing rotors were drilled. There were two reasons - the holes gave the "fireband" boundary layer of gasses and particulate matter someplace to go and the edges of the holes gave the pad a better "bite".
Unfortunately the drilled holes also reduced the thermal capacity of the discs and served as very effective "stress raisers" significantly decreasing disc life. Improvements in friction materials have pretty much made the drilled rotor a thing of the past in racing. Most racing rotors currently feature a series of tangential slots or channels that serve the same purpose without the attendant disadvantages.
Drilled are a no-no pretty much everywhere these days. Too prone to cracking. Also, the reduce the surface area of the rotor, which means less overall braking performance.
As for slotting - IF you are OK with swapping brakes rotors more often, and IF you have already removed all non-race portions of your brake system (stock master cylinder, ABS module, rubber lines, etc.), and IF you believe you can tell a meaningful difference between a 3 millisecond initial bite and a 5 millisecond initial bite, and IF you make consistent enough laps to where these milliseconds will eventually add up to seconds . . . then it MAY make sense to go with premium slotted rotors (like the ones that cost $500 per rotor).
If not, then stick with regular iron rotors.
00 Trans Ram is offline   Reply With Quote
Old 06-08-2016, 12:28 PM   #18
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Yeah....but they look cool
Old 06-08-2016, 08:55 PM   #19
Bobfly
OspreyTech
Bobfly's Avatar
I'm guessing you don't have a rubbing issue with those 315's on the back? That's a kickass brake set up you've come up with. Those are massive rotors. I'll be waiting for the package price too.
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 07-07-2016, 07:30 PM   #20
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
anymore info on this product?
I sorely miss the wildwood 6 piston aero6's I had on my 2013.
trying to see whats offered here, or should I shoot for the Gm kit and call it a wrap?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 09-17-2016, 07:37 PM   #21
BradfordCamaro
SABIO
Old 09-17-2016, 09:39 PM   #22
Drives: 2016 camaro
Glad someone brought this back. I just called and sent an email on friday.
Old 09-19-2016, 03:36 PM   #23
JDP Motorsports
I have no rubbing issues with the 315's or 335's I've been running on 18" wheels. We have completed development on the package and I just need to finalize pricing.
I apologize this has taken us so long. We'll get pricing put together by the end of this week and get it on the website. I appreciate the support and have a great day!
Kind regards,
Jordan Priestley
801-545-4215
Old 09-19-2016, 03:45 PM   #24
Drives: 2016 camaro
No worries, know ya been doing ya racing and the optima USC shootout and stuff. Been keeping an eye on it all via Showtime Motorsports weekly documentary on youtube. Keep it going
6-piston brakes, 6th gen camaro, brakes, jdp motorsports
