![]() Drives: 2017 ZL1 Join Date: Mar 2017
Dyno
Hi guys I took my ZL1 to the local dyno to see what it was putting out standard from the factory. I was disappointed with the results tbo it put out 480 bhp to the wheels but that is on a mustang dyno and not a dynojet and it was also 110 degrees in the shop that day so it was pulling timing. If anyone knows the mustang dyno it usually gives a 15% lower figure than a dyno jet as it is a load bearing dyno and is more realistic so in theory it would of been 552bhp on a dyno jet. Has anyone else had there car on a dyno yet ?
![]() Drives: Camaro Join Date: Mar 2017
Had two stock ones on the dyno so far, the A10 made 530 rwhp and the M6 made 545 rwhp on a standard Dynojet dyno. Now keep in mind we have crap gas out here in AZ with hot dry air so we kind of suck compared to the rest of the US.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
I'm in south Texas very humid and hot here so it doesn't help I have the A10 so I'm not a million miles off most people's. I'm going back in a few days to try again once it's cooler.
The dyno jet has load as well and post realistic numbers.. the mustang dyno seems to always read low numbers though. What air temps did your car see while making the pass, and did he let it cool down significantly? I've not seen a ZL1 post numbers in the 400's yet.. I'm sure yours was due to rare circumstances
#6 | |
#7 | |
#8 | |
#9 | |
#10 | |
#11 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Seems low....
Have them run the dyno at 6am. Lol Every time I go to Vegas or Phx no one works past noon anyways due to the heat.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
#12 | |
![]() ![]() ![]() Drives: 17 ZL1 Join Date: Mar 2017
That's more like it!!!
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
#13 | |
#14 |
![]() ![]() Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
There is absolutely no way to accurately calculate a Mustang Dyno reading to a DynoJet reading.
A Mustang Dyno is definitely the better tuning tool of the two. The Mustang Dyno is a load based dyno, the only drawback is that there are a ton of variables that must be input by the dyno operator. A DynoJet uses a fixed weight drum that reads HP. It's a much more consistent reading, with no variables to input other that weather correction factor (SAE, STD), but it's not as accurate for tuning due to the load being fixed. For Internet bench racing, DynoJets are better due to their consistency. But there are still variables that never get accounted for (tire air pressure, wheel/tire weight, how tightly the vehicle is strapped down, etc.)
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
