How to read Ethanol w/ P3 Gauge?
Recently had a P3 gauge put in my car, and well when I scroll over to ethanol it reads E 0. I just had a flex fuel sensor installed as well so I assumed since i’m on 93 i’d at least see 9-12% ethanol.
My question is, am I missing a component which will enable me to read ethanol or is there a parameter when tuning the vehicle that has to be configured. Reason I ask is because my local mod shop explained that this is a configuration that is enabled when tuning the vehicle which allows the P3 to then read ethanol. But looking online I see things like needing either: Ethanol sensor or a P3 signal inverter. Thanks in advance. |
No you're not going to see anything with just 93 in there. The sensor will only pick up any level of e85 in the tank. I assume you already had the tune adjusted to read the sensor so just drop some E in there and you will see the adjustments depending on your mixture.
Normal 93 octane pump gas has about 10% ethanol, and it's reasonable to expect that it would show up on the gauge.
You’d see 10% on pump gas because pump is e10 essentially. And a real alcohol sensor will read that.
