Oil Change Hassle
I assume we all do the same thing: You can only buy 5 quart jugs of oil, so we buy 2 then measure out 2 quarts to use in lawn mowers and pressure washers (or just throw it a way). Buying 3 individual quarts costs way more than the 5 quart jug and single quarts aren't always available. WTF don't they sell 1 gallon (4 quart) jugs of 5w-30 so we can just buy 2 and be done with it? :noidea: They sell 1 gallon jugs of the oil for my Duramax, but it takes 10 quarts! So, I have to buy 3 of those and still throw 2 extra quarts away! :facepalm:
DON'T toss the "extra oil!" Find a use for it. |
Sounds absurd that you would “throw away” what you don’t use. Put it on a shelf and use it where you can.
Also an Amsoil user. 2 gallon jugs and Im all set. |
4 oil changes and the 5th is basically free ;)
This |
I buy 2 5qt jugs of mobil 1 and after all the old oil is drained I pour about 1.5qts of clean stuff through before putting the plug back in so it grabs any gunk on the way down and out :thumbsup:
Keep it for the next oil change.
Sent from my iPhone using Tapatalk |
1 Attachment(s)
Dumping brand new oil due to a minor inconvenience...amazing. :crazy:
I use the old oil first then add the new. It doesn’t go bad sitting in the jug.
Right now I have Pennzoil that I got for $22.99 cdn which is $16.67 usd |
I never considered running chaser fluid to remove any residual from the pan (I just drain and fill). Has that been shown to be beneficial, or is it more so just a hand-me-down routine for peace of mind? |
Remember conventional oil(non synthetic) in oil cans and changing every 3k miles. If you threw oil away, dad or granddad would beat your ass!
Current worst oil was yesteryears best oil choice. The times have changed for the best. Key point: just change your oil frequently and all will be good. |
