L99 sport mode not working
Hi Guys,
My 2011 2ss had never really driven any differently in sports mode until the other day. I slowed down for a corner then accelerated out of it hard and then backed off for the next corner. When I backed off it held the revs high and when I was braking for the corner it raved up and power shifted down into the next corner. It was actually working how I expected sports to work. Then coming back through the same corners again later that day if did the exact same thing. Since then I can not get it to work in sports mode the same way? What am I missing? It shifts into sports and shows “s” on the dash but drives no different to “d” What are the requirements for sports mode to work fully? |
I've only used Sport mode a few times (I always use the tap shifts) but from what I remember you just need to drive the car hard - driving "normally" won't be much different than D, but stomping on the throttle and brake pedals will let the computer know you want to go fast.
I’m thinking there’s something else going on not allowing sport mode like the engine temp isn’t getting hot enough? The analogue gauge sits at 1/3 at running temp which is weird as all my cars normally sit at 1/2 way point. On the digital gauge it’s 189 deg f normal running temp. |
While driving in M (Manual Mode),
if Tap Shift has not been activated, the transmission determines when the vehicle is being driven in a competitive manner and will select and hold the transmission in lower gears and have more noticeable upshifts for sportier vehicle performance. My 14 SS Sedan does the same thing, I've only been able to activate it going around corners. You have to hit the gas hard going around the corner. |
Yea this makes sense as it happened straight out of a corner, maybe there’s a sensor that picks up g force to initiate it? |
It could use the yaw sensor with the wheel speed sensors.
I have found that it can be a bit too aggressive on the downshifts sometimes. It's funny when it happens and you aren't expecting it. I rarely ever use it though, as I just use the paddles 100% of the time.
I wonder how well it works for road track usage - whether the algorithm is smart enough to keep it from actually becoming a hinderance. My god, I really wish the tech in the new 10 speed autos had matured sooner so we could have gotten it. The 6L80e is a good, solid trans that can take a ton of abuse, but smart and quick it is not. |
I just can’t get it to go into this mode and the one time I did I didn’t see any message |
