Skip Shift Eliminator
Anybody else find it practically impossible to get their skip shift eliminator installed? I can't even get my hand up there to pull the factory plug. Any words of wisdom would be appreciated.
Know any kids?
Yeah, but there’s not a jack stand in the world i trust that much. :)
Long screwdriver:dizzy:
Space is tight on Gen6 for installing the skip shift eliminator, especially since you have to use a small screwdriver to release a clip. I easily guilted my dealer to put my '17 on a lift, after they installed a front license plate bracket when they promised they wouldn't. Even with it fully lifted it took a little effort. But if all else fails, try to get it done with next oil change assuming car will be ramped or lifted. Good luck.
Check out this thread http://www.camaro6.com/forums/showthread.php?t=490112
May give you some help and ideas. |
I've done it on my ZL1 and on my neighbors 1SS1LE. It's doable but not easy. My hands are not small either. The one positive is that the connector that exists that you input the skip shift eliminator into is very easy to discconnect and to reconnect once you reach it.
Save some time and get it tuned. If you plan on doing any modding you'll need a tune sooner or later. You can tune that waste of time skip shift eliminator right out.
Mine was super easy. Just handed the dealer tech the SSE at my first oil change at 500 miles and said, "Here, install this for me." My '13 ZL1 was just as easy.
I just did mine and it is a PITA! I watched the how to video on line and it looked pretty easy but in reality there’s just no room up there for your hand. I used a short flat blade screwdriver to unlatch the clip and the rest was a piece of cake!
Turn it a little bit more (RPM's) and it eliminates the skip shift. I bet I've had it pop up 3 times in a year. Not an issue for my driving style.
