Originally Posted by djfury05
(Post 9877328)
Easy.. One is a positive displacement blower and one a centrifugal. Whipple will start out extremely strong and lose steam at upper rpm. Procharger is a more linear and predictable power curve and easier on parts.
Depending on the size of the Procharger you can make significantly more power up top. Also with the Procharger cones the opportunity to add port injection aka an extra 8 injectors. You can't do that with a positive displacement blower. So you'll have more headroom in fueling with the Procharger.
Personally I went with the Whipple because it suits my driving style and likely will be easier for me to install. Plus it was much cheaper.
There are a couple examples out there of the Whipple 2.9L over 900rwhp so big power is possible just not at the level of a big Procharger.
+1!
Depends on how you want your your power curve to look like and your ultimate goal. Top units aka roots/twinscrew = more power down low, centrifuge = more power up top. Looking for a 1k+ rwhp setup? Looking for 700-800ish and keep it simple-ish?
One of the pluses to PC for example is that you can start off with just a any head units then can change up the head unit to a different one, F1, D1X, P1X as upgrades or just to change up the power lower or higher. PC also does give you the option to grab an intake manifold (for LT4) from them (i think it's like $1200 though).
I do wish PC setup was more like C7s. Using the stock intake location (the body is designed specifically for extra air flow at these locations...), away from headers and all... The intercooler is a BEAST though. Heat won't be an issue unless you go and get aftermarket headers and not get em coated... I am sure intake location could've been that way if they could have done it (at least I hope so). I have seen hell of a lot more testing done on the c7 by PC than for the Camaro though which I am sure helped a ton for the camaro but still as I didn't hear or see the PC team on track doing RnD like they did for the C7 before releasing the kits.
