Been Lurking
Been lurking here checking out the ZL1 subforums and for sale section. Might as well post my current project.
1967 Camaro (under the knife again) ZL1 LSA T56 Mag Vintage Air Speedtech front subframe Chasis works triangulated 4bar DSE Frame connectors and mini tub A few pics Before Tear down http://i54.tinypic.com/jb31o7.jpg http://i56.tinypic.com/34868aq.jpg Tear Down http://i66.tinypic.com/295s86c.jpg http://i66.tinypic.com/b9is07.jpg MORE RUST http://i68.tinypic.com/2cckuj6.jpg Seam Sealer nearly removed http://i66.tinypic.com/2hxob50.jpg Right now I'm focusing on the firewall, subframe connector install and redoing the under side. I just got the subframe in last weekend and plan to hit it hard in the next couple weeks. |
Welcome aboard.
Nice!
Nice 67! Welcome!
Welcome and good luck with ur build. Nice ride
Welcome! Looks like a great project!
Thanks guys!
Welcome aboard! Nice classic! :thumbup:
That car looks sick!! I love the Smokey Yunick inspired paint job.
Welcome to our happy little corner of the net, and to Camaro5/6. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, dad's, wives', husband's, girlfriend's and boyfriend's here don't care....and take it easy.
http://i886.photobucket.com/albums/a.../NewFridge.jpg oh...btw....every once in a while a food fight breaks out...so you may not want to wear nice clothes here. Welcome!! |
A few updates.......
Firewall fill plate just about in. Need to finish some bottom a little but its just about done. Tack http://i63.tinypic.com/2rw80fb.jpg ground down http://i63.tinypic.com/2mdj47d.jpg up next Sub frame connectors and Engine mock up and firewall down bars DSE subframe connectors are in Down bars are in. I decided to weld them in with a removable tube adapter and the plates welded to the firewall. I have some clean up to do still. Next is to finish the trans tunnel with the speedtech cover then power wash / steam the underside and get the whole thing ready for undercoating and firewall paint. http://i44.photobucket.com/albums/f9...ps8bu6xho9.jpg http://i63.tinypic.com/15yam1s.jpg http://i44.photobucket.com/albums/f9...pskvtt00ws.jpg |
Engine Mockup:
http://i44.photobucket.com/albums/f9...ps5w9vkign.jpg The Good Mast Oil Pan fits nice The engine fits the steering rack clears the pan and rack. The not so good: Driver side header needs to be modified to make the steering connection. I know Speedtech makes a custom header but 1 primary tube modification and it will fit. http://i44.photobucket.com/albums/f9...ps7z58xfed.jpg The crank pulley will interfere with the crossmember when i use the over drive LSA Pulley. The alternator is also very close. I will make pockets to fit these better. http://i44.photobucket.com/albums/f9...pslvcwubj4.jpg http://i44.photobucket.com/albums/f9...psidufaxua.jpg I need to verify the Dirty Dingo low mount A/C will fit and then I can begin modification on the frame. |
Been working on the header modification.
There was no room to go above. Not excited about the overall length and additional bends but for now its fine. I need to pinch some pennies and not buying $1500 headers is a good thing. i'll have my buddy tig them up but should have around $550 in them once done. http://i65.tinypic.com/34hf7m1.jpg http://i67.tinypic.com/2ajtd9h.jpg http://i67.tinypic.com/t8tfz8.jpg http://i65.tinypic.com/2ccnzpf.jpg http://i65.tinypic.com/f1wpab.jpg |
this is going to be an absolute beast! I always loved the '67
