Stock rear SS rims fit on front?
Will the stock rear wheels fit on the front with no rubbing? If so, how much rubber could I stick on the rims with no rub issues?
Yes. 275s are really it, and the 20x9s are the minimum size
I run the 20x9's on 275-40-20's all around with no problem. The square setup is how the car should have come from the factory for rotational, load and handling purposes.
I would not run anything wider than a 275 on the stock 20x9's. You may want to consider 275-35-20's for a slightly lower profile. |
I was thinking of doing this setup myself. Is there any noticable offset between front and back?
I want to do that too. Is it a real noticeable improvement? Does it increase the chance for rock chips behind the front wheel, or is that just a 50/50 chance anyway?
It will increase the chance of rock chips on the rear gills. Sent from my AGM, 2SS/RS |
I'm just looking to do this for the track. I like my forgestar rims. Going to us my stock rims for track tires.
What tires do all of you like to put on this square setup?
I'm running Invos. Think about a 275-35-20.
