Broken glass in rear speakers
So a few months ago(If you see my posts you'll know i have bad luck with everything that has to do with my car), my Camaro was vandalized.
http://i1094.photobucket.com/albums/...294522508.jpeg Was luckily covered by insurance with no deductible. But still Annoying. What wasnt covered was the broken tail light and the annoying pieces of glass rattling in the rear speakers. Anyone know an easy way to get the broken glass out? Or am i going to have to disassemble the entire back of my car to get out the glass? Thanks for your help. |
I would think a shop vac would help.
Don't the speakers come out through the trunk? That would be the best way to make sure to get them all out. Or you could take the car to a stereo shop and have them upgrade your speakers.
He's right drop them from the bottom should be 4 bolts on each corner. If my trunk wasn't full I would take a look.
Not that easy from what I`ve read, you have to tear out the whole back area to get the speakers out I`m pretty sure.
I would try compressed air but be careful not too much pressure or you may damage the speaker.
You need to take a lot apart. To get the deck lid off you need to remove the side pillar trim in the back seat. Speakers come out the top not the bottom unfortunately. Would be much nicer for replacing the stereo I'll tell ya. You could gut the speakers and remove them from the bottom and replace them though. You would end up destroying the speakers that are there. There is only one bolt that holds them in you could punch it out from the bottom. This is a very brute way to do it and I wouldn't recommend doing it since gutting the speakers could put more things to rattle around up in there, but you would gain access to the space and theoretically get a shop vac in there.
If you want it clean in there its all gotta come apart. If you don't have time you could ask a stereo shop to clean out in there for you. They are fast at removing panels and such, and a relatively cheap shop rate. Even though they aren't installing speakers they may still do it if you are nice enough about it. I would replace the speakers and dynamat while its apart anyway. By the way if it was covered under insurance, they should be recommending a shop to clean it out. |
Play some bassy music, shop vac the speakers with them playing. Eventually you should hopefully get everything.
