Exhaust Flaps
Is it true that you can set the exhaust flaps to stay open in the setting menu of the 2018 ZL1 1LE?
I did and got an engine lite on. Put the fuse back in and had the code re set??
Did it on my 2018 ZL1 1LE and no light and works perfect.
Can you share the exact fuse...I know it says exhaust. I think it was 51 or 52?
I pulled mine and got the engine lite on. Cant drive around with that lite on. Really a small enough change at low rpm's? |
That said, the only real difference I noticed between “track” mode and fuse pulled was a little extra exhaust noise at cruising speeds. The flaps still close (at least partially) during light throttle driving above a certain speed. I wish GM had programmed track mode to stay completely open, but it is what it is. |
I have had mine pulled for three weeks on my 17 ZL1 no problems
Thanks for the replies...
So can anyone with a 2018 1LE show me the exact fuse to pull? I have the #51 and pulled the 15 amp fuse and got the engine light on 2 times...Help!!
You’re probably pulling the wrong fuse. There is a video on YouTube you can reference to make sure you’re pulling the right one.
I looked up the fuse in the owners manual, and it’s 51 in the engine compartment fuse box. On the 5th gen the exhaust control fuse was in the rear box.
