Race star wheel size to fit without adapters of spacer or whatever
Will these fit without issue?
No cutting or grinding or adapters? My brakes are brembo. Race Star 92 Drag Star Bracket Racer Metallic Gray Wheels 92-795153G Here is a link https://www.summitracing.com/parts/rce-92-795153g Is there a reason to get 10.5" wide rims over the 9.5"? I see a lot of people run a 275 on there 9.5". And I'll be running the stock 20" rims and run flats at meat go start. I don't have power to necessitate skinnies. I'm stock. I just want to run good time before I go to power mods. |
That wheel is the wrong bolt pattern. The bolt pattern should be 5x120.
Thank you, big mistake there.
