V6 to V4 with A8
Is there any way to tell when V4 mode kicks in with the V6 A8 and standard gauge cluster?
Mine displays it on the screen when you stroll down to the gas amount display I believe, using the arrows on the righ-hand side of your steering wheel.
If it kicks off 2 cylinders you're driving it wrong.
It's called active fuel management in the owners manual. It only applies to auto transmissions. It shows in the fuel management cluster when you are in 4 cylinder mode.
It absolutely can be felt, V4 mode feels like driving an underpowered sedan with little torque to show. Then again, it yields 45-50 mpg at roughly 55-60 mph and isn't overly intrusive. |
All in all, it seems to deactivate almost immediately when more torque is needed, and I can understand why---if it didn't, likely much more people would complain about sluggishness. I'm considering the trifecta tune, because that makes a clear distinction between tour and sport mode, namely it disables cylinder deactivation in the latter, which makes a lot of sense to me. Quote:
I wonder how much fuel it actually saves. I expected better MPG with the V6, A8 being a six cylinder, with the fuel management system and I drive with a very light foot, cruising at 50-55 MPH, 1500 RPM most of the time yet I get only 24 MPG- at best and when I monitor the meter. My other car a WRX- semi fast car- 4 cylinder turbo, no fuel management system and with AWD I drive light footed the same way and get 32 around town and 34-40 on the highway. I'm afraid if I drive the Camaro any harder the mileage might dip in the mid teens.
I've seen the message once since I owned the car, i guess that's a statement about how I drive.
So V4 isn't active over 55 MPH?
