Universal fmic help
Tomorrow I'll be purchasing a universal front mount intercooler from cxracing, along with piping, couplers, and t-bolt clamps. I'm curious to if the dimensions of his intercooler will fit.
https://www.cxracing.com/intercooler...nlet/IC0006-30 |
I think it would be wise to buy a kit that is designed for the Camaro. ZZP is a proven name in the LTG community and they make a FMIC kit I believe.
shit!!!! If they had the pipes i would jump on this as i have a tune upcoming.
The one I got from mishimoto is 24.5 x 13.1 x 3, and I know it will fit. I imagine you'll be fine.
Go for it! Give us a write up when your done.
You'll go a lot faster, and save a ton of money if you altered your view a bit. No one is reinventing the wheel here, it's just an intercooler, and those have known performance characteristics. Y amount of core volume will provide Z amount of cooling. You don't need to pay the asshole tax! I'm not saying YOU specifically, I mean YOU as in everyone that reads the post. |
I’ve pretty much always made my own kits, back before all the Chinese shit hit the markets you were lucky to find a performance intercooler (no pipes) for under $1000. Back then we’d use Isuzu NPR intercoolers for cheap front mounts. Then I’d just order a few mandrel bent aluminum pipes, couplers and cut to fit. You can mark the positions and look for a local welder or fab shop to join the pipes, or just run a bunch a couplers. To bead roll the pipes I would just take a set of wire crimpers, cut off the cutters, and your left with a low budget crimping tool.
It’s a little bit of work, but it will save you a few hundred $$. Smart move and good luck. |
When I eventually get the 'big' build going, that will definitely be an air to water setup, as air to air can never bring boost temp below ambient temp. I'm really glad to see you taking this project on! I wish there was more of a DIY/"can do" type spirit within the community. That is part of the reason why EBM's are so much faster currently! No one is willing to try anything outside the box! |
